7-Bedrock
Line chart widget multiple data populating reg...
In line chart widget ,is there a way to display multiple data values for a single value in x axis?
For example , if am displaying data with respect to every minute , is there a way show multiple values for each minute?
Thanks in advance,
Sadagopan PSSKP
22-Sapphire I
Not sure if I'm interpreting this correctly, but wouldn't that be multiple series?
Every minute I measure temperature and pressure that would become two lines on my chart.
The other thing you can do is map values into the tooltip to show additional information for a point.
Support
Hi @psskps.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
@psskps
Requirement is two map more than one data set with same time frame?
Ex: time= x-axis
current and temp on Y axis
Correct me if my understanding is wrong.
Mohit
