Line Chart Y-axis is not autoscaling
Hi Team,
The Y axis of line chart in ThingWorx 9.2 is not auto-scaling even Y axis maximum is set on Auto.
The use case is that we need to autoscale the y axis as per the referenceline1value property of line chart. Actually when the value of reference line is either less than or greater than the values displaying on Y-axis of graph then it is not visible as the Y-axis is not auto-scaling with respect to the referenceline1value property.
Thanks in advance.
Hello @RK_0705,
I have checked that autoscaling property is only available in Label Chart Widget. But as mentioned by @VladimirN , You can reach out to PTC support team and report this issue.
Bhawna
Try to open a support "Case", here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
Hello @RK_0705,
Bhawna
Support
November 29, 2021
Hi @RK_0705
For requesting functionality that does not currently exist, it is requested that you post a suggestion on the ThingWorx Ideas board.  By doing so, allows others to vote for its inclusion in a future release, thereby improving its chances of consideration.
--Sharon
