List/Dropdown/ComboBox
Out of List/Dropdown/ComboBox - which one will work efficiently?? Iam facing slowness in combobox
There was a bug in list widget of 8.4. Now in 9.2 version all problems related to list solved.
22-Sapphire I
Can you check with the Dev tools open so it can show you what exactly takes how much time?
i tried using chrome's F12 developer option. Am not able to see execution time of code. Can you guide me where exactly we can see the execution time??
22-Sapphire I
It would be on the Network tab
Support
Hi @AP_9587236.
Have you found a solution to your problem?  If so, please post it here and mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
AP_958723617-PeridotAuthorAnswer
