May 28, 2018 12:18 PM UTC
Live Mobile location tracking
I need to build a mashup with Google Map showing live location of my mobile device. Is there any links/tutorials that can help me with this?
Avinash
supandeyAnswer
May 29, 2018 9:57 AM UTC
@agangaiah links to all the proposed options are already in my previous response. Let me know if you have issue accessing those. They all are pointing to ThingWorx Developer portal.
May 29, 2018 7:05 AM UTC
Hi @agangaiah  I can think of some options, but I suppose for you it depends on what sort of mobile device it is and how do you plan to send data from the device to ThingWorx.
If bandwidth / connection is not an issue you could look into making REST calls from the device to ThingWorx Use REST API to Access ThingWorx if the device is limited in terms of its resources you could consider using MQTT protocol to send data to ThingWorx, there's a MQTT extension available for ThingWorx on ThingWorx Marketplace
Another option could be to use ThingWorx C SDK
agangaiah5-Regular MemberAuthor
May 29, 2018 9:55 AM UTC
Great!!! Thanks for the response. Lets say that I do not have any Bandwidth issue. Can I make rest calls?
Is there is any documents/links available for this?
Avinash
supandey5-Regular MemberAnswer
