Local Binding Limits in Thingworx
I need to bind one property of a thing to another property in 200 or more things. Is it recommended? If not, please suggest a better alternative.
I have shared the requirement in the diagram given below.
With regards
Yedukrishnan
Hi @slangley,
We put local binding to matching properties of 150 things and are working fine in runtime. I needed to understand the impact it could cause in runtime.
With regards
Yedukrishnan U
Hello @Yedukrishnan
your image did not attach successfully.
Hi @PEHOWE ,
I have attached the image in previous comment.
With regards
Yedukrishnan
Support
Hi @Yedukrishnan.
If I'm understanding your requirements, you simply need to create a thing shape to extend the properties.  If this is not correct, please provide more details around your use case so we can respond accordingly.
--Sharon
Support
Hi @Yedukrishnan.
If you have found a solution to your problem, please mark one of the previous posts, if appropriate, or post your own solution here for the benefit of others on the community.
--Sharon
Yedukrishnan14-AlexandriteAuthorAnswer
Hi @slangley,
With regards
Yedukrishnan U
