Location through IOT
How can i track my device which contain MT5931 chip-set with MT2502. Is there any direct api to get the location. Please help me.
Thanks in advance.
Hi @sprakash-2 seems like it has ARM processor, you could consider using Lua Script resource to connect that device to WS EMS which can pass on the data to and fro to ThingWorx server or other option could be to use the ThingWorx C Edge SDK.
You can access more detail on both via these two links
1. ThingWorx Edge WebSocket-based MicroServer (WS EMS)
2. ThingWorx Edge C SDK
Both can handle the devices with low/limited compute power on board.
