slangleyAnswer
Support
Hi @EM_9923519
To preregister your instance, go to sc.thingworx.com in your browser.  If you're unable to access this site, follow the instructions in this article to request access.
If you find you already have access, click the icon in the upper-left under PTC Solution Central, then select Instances.  Finally select the Preregistration tab, then click Preregister to preregister your instance.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @EM_9923519
--Sharon
Thank you, I will request access, and let you know, I didn't know this site
