Log4j in ThingWorx
Do we have option to incorporate Logs like the Log4j in ThingWorx application?
Thanks in advance,
Shalini V.
At which level?
  1. Javascript server side -> You already have a logging feature (look on snippets debug, error, info, warn)
  2. Java Extension Server Side -> Actually it's using Log4j, you just need to follow documentation in order to use it.
At which level?
Support
Hi @svisveswaraiya_285988
If the response provided by @CarlesColl answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
