Apr 25, 2020 9:51 AM UTC
Login Implementation with username password via Things Service for mobile application Thingworx
I am developing a mobile app that communicates with TWX via REST API. I have created MobileConnector_TH which having services that pull the data and revert it to mobile via HTTP Rest API.
Problem statement:-
I have one service written in MobileConnector_TH - validateUser(Username, Password)
Which contains the following code
var params = {
url: me.IPUrl+"/Thingworx/action-login?OrganizationName="+organization+"&thingworx-form-userid="+username+"&thingworx-form-password="+password+"&x-thingworx-session=true" /* STRING */,
contentType: "text/html" /* STRING */
// result: STRING
var result = Resources["ContentLoaderFunctions"].GetText(params);
This returns HTML webpage data into a string. I am unable to find any specific scenario to validate username&Password via Service. It showing the same result with the wrong password/username.
https://community.ptc.com/t5/ThingWorx-Developers/Authentication-with-User-Credentials-via-Rest-Api/td-p/585890
Apr 29, 2020 6:32 PM UTC
@sushantpatekar , Not quite sure that I can address all of your questions. I have used a couple of different REST API calls to get information on the users in the system.
To get a list of the users defined in the system. For my testing I used POSTMAN. The first question I tried to answer was can I get a list of the users on the system. To do this requires that I have an AppKey, you only do not want to share information with just anyone.
  • Get Transaction
    • URL: http://localhost/Thingworx/Users
    • Header values
      • appkey : <key value with priv to see users>
      • Accept : text/xml
        • I used this because I thought something you can parse is better other values exist such as "text/csv", "text/html"...
    • This returned a XML document which contained the list of user names.
Second question now that I know a user name can I get information about that user
  • Get Transaction
    • url: http://localhost/Thingworx/Users/TestUserName
    • Header values
      • Accept : text/csv
  • This reply is a success (200). But not a lot of data. Take a look at the following URL to get an idea of what you can request. http://<youtThingWorx:<port>/Thingworx/Users/<known UserName>
In your post you are trying to make a REST API call and perform a login. Try the following.
  • POST transaction
    • URL: localhost/Thingworx/action-login
    • Header
      • Accept : text/csv
    • Body x-www-form-urlencoded
      • thingworx-form-userid : <user name>
      • thingworx-form-password : <password>
  • In my testing with POSTMAN this returned a status of 200, and a session ID
Now an item to be considered this approach is sending a username and password as clear text between a device and a server. NOT good security
Let me know if this helps
Peter
