Login organization
I have a organization where 20 users logging in currently. Most of the times, the logging to organization getting failed even for correct user credentials. If I delete the browser history, cache, cookies, then it is working fine.
What is the solution for this. How to deal this issue when the login users got increased to hundreds and thousands??
Support
Hi @AP_9587236.
What browser is in use?  Is the system in use shared among the 20 users.  Do you possibly have a browser extension installed that could be interfering with subsequent logins?
--Sharon
What browser is in use? - Chrome
Is the system in use shared among the 20 users? - No. 20 users logging from different systems but to the same server.
Do you possibly have a browser extension installed that could be interfering with subsequent logins? - No. We didnt installed any extensions for browser.
I did screen recording and attached the file here for your reference.
20-Turquoise
Have you tried a different browser? Is your autofill-on, did you have a chance to notice if perhaps it fills out imporer credentials automatically?
Have you tried a different browser? - No. Ill test in another browser also.
Is your autofill-on? - No.
Did you have a chance to notice if perhaps it fills out imporer credentials automatically? - The correct credentials which is failed to logging in, will work after clearing history and caches.
Support
Hi @AP_9587236
If possible, you might want to try with a different browser the next time you experience the issue to determine if it is related to a specific browser/version.
--Sharon
Okay Thanks
