11-Garnet
Logout button - redirect mashup
The log out button has a redirect mashup option, I created a logout mashup and then provided the mashup name in the input of the log out button. The functionality doesn't seem to work as it should. When I click on Logout button it asks me to login instead of redirecting me to that mashup! Can anyone help me to solve this issue!
The Logout button is used to end the current User session, you need to re-sign in;
If you just need a button that helps you go to another mashup page, you should use Navigation widget with - Replace selection in TargetWindow field
biswa11-GarnetAuthor
11-Garnet
The log out button has a redirect mashup option! I was wondering if I can use that but before redirecting its terminating and not loading up the mashup!
That one means after you re-signin, the mashup you opened will be the redirected to the one you configured.
Support
Hi @biswa.
Please take a look at this post to see if it resolves your issue.
--Sharon
