Making Notification feed Dynamic as per Menu item selection
I am going through one requirement where I want to have notification feed for all Module(in my case Menu items). and as per selected Module related Notification should be displayed..but I have doubt that where to put Notification bell icon/button that is in Master or for each Module mashup?? when I put it in master then how can I display notification for each module and if I put it in each module is it good approach?? please need help
22-Sapphire I
Generally speaking you would have icons in your master that relate to your module and you'd see numbers displayed in or just above it to the right.
I would probably copy that type of visualization.
If you have your menus on the left and no icons on the top, you could add numbers to the left or right of your menu icons, not as visually appealing since it can't be associated directly with the menu icon.
