Map Pointer to Mashup
Hi All
I have a use-case in which I want to implement the following :
I have a list of sites on clicking an item from list it should show the location on the map and on clicking the map pointer It should navigate to a mashup. I was able to achieve the first step wherein on click of the item from list it should show the location on the map. I am bit confused on the second part as to how to link the pointer with the mashup. How should I input the location in the the service to get the desired mahsup
Regards
Ketan
PaiChungAnswer
22-Sapphire I
Add the mashup name to the same data source that you are using to display the point on the map.
Bind that mashup name to a navigation widget (or use an embedded mashup/mashup parameter)
then use the onclick ... maybe double click I forget what events the map has to navigate.
PaiChung22-Sapphire IAnswer
22-Sapphire I
ketanaga1-VisitorAuthor
Thanks @PaiChung .
The approach worked
