Map Widget string/integer value display on particular locations
I am trying to implement map widget, based on locations I need to populate my count data on the location ( for ex. india - above india i need to show integer or string values dynamically inside my color design ). now I need to show total count of each country value inside my green or amber circled state def.
Hello @sabharees
Thank you for reaching out to PTC
Please check this article  and see if it helps you with your use case
Toolika Dixit
