11-Garnet
Mashup Configure binding ThingName
I am looking at a mashup looks like carried forward from previous version of ThingWorx. I started working learning from 9.3. Not able to find any documentation.
Can I get information how ThingName is configured? .
ATT1405Answer
11-Garnet
Found the answer
Mashup--> explorer
Properties and select configure properties of selected widget and add parameter
these new parameters will be displayed in mashup properties and bind them as required.
22-Sapphire I
You should be able to get to the help center from Thingworx help.
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Welcome.html
Your screenshot is showing a mashup with a mashup parameter and from somewhere, not shown the parameter value is provided.
My best guess, since it is called ThingName, there is some other service or parameter or selection in a parent mashup, that is providing a default or selected Thingworx Thing.
ATT140511-GarnetAuthor
11-Garnet
Like loaded events which gives output in the same way Thingname is property, not able to see the binding, neither it has been configured in mashup property tab.
22-Sapphire I
I'm not sure if you've considered taking the ThingWorx fundamentals courses, but that should give you enough basis to understand Mashup parameters and the concept of 'dynamic' services used within a mashup, which is most likely why the ThingName is being passed in.
ATT140511-GarnetAuthorAnswer
11-Garnet
Found the answer
Mashup--> explorer
