Dec 22, 2019 4:47 AM UTC
Mashup conversion from static to responsive
Is there a way to convert a static mashup to a responsive mashup (advanced)?
It would be nice if this is possible since I don't want to start all over and bind the services to the widgets and also set up all the validators.
WillieAnswer
Dec 23, 2019 9:02 PM UTC
Hi @slangley ,
It seems that I had mashups (static/responsive) mixed up with layouts and panels.
I didn't know I was using a responsive mashup.  In this responsive mashup, I had a panel in panel to create static dimensions.  I removed the panels and replaced them with layouts so that the widgets would work with any screen resolution.
Now I understand that a static mashup requires height and width dimensions and a responsive mashup does not since it is dynamic.
Willie16-PearlAuthor
Dec 22, 2019 4:56 AM UTC
Answer: Not possible as of 5/2018
https://www.ptc.com/en/support/article?n=CS286115
Support
Dec 23, 2019 8:22 PM UTC
Hi @Willie.
You can copy/paste between mashups but of course, this will not carry over the bindings.  Which version of ThingWorx are you running?
--Sharon
Dec 23, 2019 8:25 PM UTC
Hi @slangley,
I was able to work around it by using layouts.  I was only using panels initially.  I am on 8.4.5.
