mashup layout widget
I using layout widget to divide to three section.
I wonder if there is a difference between dividing three sections into one header 2 columns and 3 columns.
raluca_edu
Yes, there is difference in the formatting, when you are using header the height is less than the row/column.
To see the difference, in mashup Runtime you can open Inspect Element (right click on any of row/column) to see HTML code and CSS.
Hope it helps,
Raluca Edu
raluca_edu
Hope it helps,
Raluca Edu
