Mashup Loading Errors
I am having an unusual problem with the mashups in Thingworx.
I have a dropdown list that and navigation widget, where the selection in the list opens a mashup.
For a few Mashups, it works just fine, but for a majority of them I receive an error of the following, "Could not load 'Mashup Name', internal exception 3".
Any suggestions.
Rami
    ThaveshniAnswer
    I found my error.
    It was due to an extra / in my URL berfore thingworx.
    https://192.168.1.1//Thingworx/Runtime/index.html#master=MasterMash&mashup=Home
    the correct URL is:
    https://192.168.1.1/Thingworx/Runtime/index.html#master=MasterMash&mashup=Home
    Hi Rami,
    Which browser are you using? If you are using Internet Explorer , could you try using Chrome or Firefox and let us know if you are facing the same issue?
    rmasoud11-VisitorAuthor
    Hi Janet,
    I was using Chrome, but IE was giving me the same result.
    What is your Thingworx platform version?
    8.0.0.
    I can open the mashups fine if the navigation widget is set to new window, but I receive the error when trying to have a popup window.
    Hi Rami Masoud,
    Could you please try changing the dimensions for  FixedPopupWidth and FixedPopupHeight settings and let us know the result.
    Same result as before.
    22-Sapphire I
    April 16, 2019
    1. Result is repeatable? ie always the same mashups that do not work?
    2. Anything that the ones that do not work have in common? Spaces/Special characters in the name of the mashup? Responsive vs. Static
    Thaveshni1-VisitorAnswer
    I found my error.
    the correct URL is:
