Mashup parameter changed event
I would like to know when/how does the Mashup Parameter's changed event is triggered? I have seen that whenever we add any mashup parameter, we also get the 'changed' event corresponding to that parameter. But I would like to know when is that event triggered, is it 'always' or on 'data/value change'. Like for parameters inside a thing we can configure the event by choosing the data change type as value, always, never etc., in similar way is there some way to configure mashup parameter's changed event?
I have a case similar to something as in https://community.ptc.com/t5/ThingWorx-Developers/How-to-react-on-submashup-changes/td-p/517353 but not exactly using repeater.
Please let me know if some more inputs are needed from my side.
Regards
Aditya Mittal
zyuan1Answer
For String type of property, the Always and Value is actually the same.
We don't find a place to set the threshold of the Mashup parameter, so I'll consider it as Always
amittal-31-VisitorAuthor
The problem is, I am using mashup parameter changed event in my implementation, and sometimes the event triggers and sometimes not when the value of mashup parameter is same. However it always triggers when the value of mashup parameter is changed. So I am not sure what could be the reason of it not triggering on some occasions.
What's the datatype you used for the mashup parameter when "the event is triggered while the mashup value is the same" ?  Have you consider the precision of the value you used?
