Mashup Parameters
Hi I am taken over the project which was developed by someone else. I didn't get KT and tech documentation to get high level knowledge about it.
When I am going through the mashups.. lots of mashup parameters from collection widget is passing to many of the mashups. I am not able to follow the flow of mashups. Any technique or method is there to identify the flow of mashup parameters. I want to figure out which mashup parameter value passing to which mashup(name of mashup).? How to figure out this?
22-Sapphire I
There really isn't a easy way, but you would probably click on the collection widget and look at the bindings window. then you would also check the 'bindings json' in each collection widget.
