mashup template
Even if we created a mashup template, how to assign it to every mashup?? What is the use of mashup template entity?
PaiChungAnswer
22-Sapphire I
Based on what I can read in the help center
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx%2FHelp%2FComposer%2FVisualization%2Fmashuptemplates.html
You can't apply it to existing mashups.
It helps you get the starting layout you desire to work with, maybe if you were doing a lot of 'child mashups' that all had similar form factor or the same base services it speeds up things?
PaiChung22-Sapphire IAnswer
22-Sapphire I
thanks
