8-Gravel
Nov 2, 2017 11:48 AM UTC
Mashup Widget Custom Dialog API
Hey guys
I have gone through all the Widget creation documents, but cannot find the "Mashup Widget Custom Dialog API" documentation being referred to. I need to create a configuration page for one of my widgets, but I have no idea how to do it.
Is there any documentation that specifically describes how to use the customEditor and creating the TW.IDE.Dialogs.xxx dialog that I can use to set properties of my widget (using eclipse)?
Regards
Anco
Nov 20, 2017 8:48 AM UTC
Hi Anco, sorry for limited detail on that in the available documentation - i'll check this out and will get back to you.
Nov 20, 2017 9:01 AM UTC
Hi Anco, The better documentation that you may get it's going through widgets that already have Configuration ( Grid, Data Filter, Property Display ) you can download it from the server web folders. Best Regards, Carles.
Dec 20, 2017 1:21 PM UTC
Quick update, an enhancement Jira ticket has been opened to address the missing detail on this topic. This can be tracked here in the KCS article https://www.ptc.com/en/support/article?n=CS276506
Dec 22, 2017 10:17 AM UTC
Update: R&D has closed this enhancement Jira with statement that Widget API is an old reference document and shouldn't be used anymore. Instead please refer to Extension Development Guide
