May I display the units for a value into the mashup?
If I have my property number which unit is in % is it possible to show into the label widget (or into any other widget) both the value and the unit?
So instead of 50, I want to see 50%.
Obviously without resort to another property which is the join of me.property+'%'
22-Sapphire I
Usually I just use a Value Display widget and a label widget.
fmanniti1-VisitorAuthor
Yes, it's also what I was doing but in this case I'm forced to have a fixed distance between number and unit so if I have 100 the result will be
100%
if I have 5 it will be
5  %
It's not a big deal, I just hoped there was another way.
Hi Fabio, on the ValueDisplay widget you can align the number to the right ( Alignment=Right )
Hi the way I have done this is by using an expression.
Add your param and then add a string type for units when you configure.
Set the output to the label
Change the expression Param+Units
Change the String for the Units in the properties box
