Jan 16, 2025 9:53 AM UTC
Media to grid widget
hi,
can I add media ( icons ) to grid ???
I tried several times but the media image is not displayed on the grid only the path like /Thingworx/MediaEntities/Media name only this path appears.
Also I made the column configuration Image render.
Note : this grid binded with infotable and the column in the infotable which represent the media is string type
VladimirNAnswer
Jan 16, 2025 10:22 PM UTC
Article - "How to display image in "Grid" widget in ThingWorx": https://www.ptc.com/en/support/article/CS237433
VladimirN24-Ruby IVAnswer
Support
Feb 28, 2025 6:09 AM UTC
HI @MS_11949745
It appears that there is a possible solution to your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
