Menu Bar Widget Overflow Menu showing after pressing expand/colapse toggle button
As I understand it "overflow menu will be displayed when the primary navigation items use 50% of the available menu bar height", regardless of the value of "PrimaryNavMaxItems". However is there a way to disable this or customize this, maybe through the CSS?
Hello @MP_10287512 ,
are you planning to use more than 5 items in Menu Widget? I assume custom CSS is not feasible in this scenario. Still let me confirm more internally.
Bhawna
Our solution right now has 10 items, plus 1 secondary item at the bottom and there are plans to add more items to the menu in the future. Thank you.
