Methods for sending data from Osi PI to Thingworx Platform
Hello, everyone,
I need some advice. My goal is to send telemetry from OSI PI to Thingworx. Browsing the internet I have read various solutions to answer my question. I wanted to ask you, the community, for a solution for data transmission, which is not using the Capula connector, and whether these proposed solutions have additional licensing costs.
Thank you
22-Sapphire I
Usually it would be an extension to read from OSI PI database.
But and I don't know if OSI PI supports this, maybe from OSI PI you can post the data to ThingWorx.
@AntonioFar  You can create one edge connector to get the data from OSI PI and to pass it to the Thingworx. There are SDKs available and create your own connector. You can read the tabs from OSI PI historian and fetch the data.
Support
Hi @AntonioFar ,
It appears that @PaiChung and @VN_10764586 provided answers to your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Tony
