Microserver luaresource stucks at creating new handler
Hello all,
We are running thingworx microserver in raspberry pi. WEMS works properly, but when we run luaresource it get
stuck at creating new handler.
PFB for lua log
[INFO ] 2018-08-13 09:29:16,343 ./luaScriptResource: Using config file: /home/pi/microserver/etc/config.lua
[FORCE] 2018-08-13 09:29:16,343 ./luaScriptResource: Starting up ....
[INFO ] 2018-08-13 09:29:16,348 luaScriptResource:main: Encryption is disabled on the RAP connection.
[INFO ] 2018-08-13 09:29:16,348 luaScriptResource:main: FIPS is disabled.
[INFO ] 2018-08-13 09:29:16,350 ./luaScriptResource: New path is /home/pi/microserver/etc/thingworx/clibs:/home/pi/microserver/etc/custom/clibs:/home/pi/microserver/etc/community/clibs:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
[WARN ] 2018-08-13 09:29:16,351 ScriptResource::initialize: Encryption is disabled on HTTP Server.
[WARN ] 2018-08-13 09:29:16,351 ScriptResource::initialize: Authentication is disabled on the HTTP Server.
[WARN ] 2018-08-13 09:29:16,353 :
[WARN ] 2018-08-13 09:29:16,380 :
[FORCE] 2018-08-13 09:29:16,394 httpServer: starting http server port=9091
[INFO ] 2018-08-13 09:29:16,397 thingworx.shape: Creating a new shape.
[INFO ] 2018-08-13 09:29:16,401 RemoteBharatForgeVibration: -- Configuration -------------------------------
[INFO ] 2018-08-13 09:29:16,402 RemoteBharatForgeVibration: scanRate: 501
[INFO ] 2018-08-13 09:29:16,402 RemoteBharatForgeVibration: scanRateResolution: 500
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: taskRate: 501
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: keepAliveRate: 60000
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: requestTimeout: 15000
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: registerRate: 43200000
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: register: true
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: getPropertySubscriptionOnReconnect: false
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: maxConcurrentPropertyUpdates: 100
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: defaultPushType: VALUE
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: useShapes: true
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: identifier: RemoteBharatForgeVibration
[INFO ] 2018-08-13 09:29:16,403 RemoteBharatForgeVibration: ------------------------------------------------
[INFO ] 2018-08-13 09:29:16,409 thingworx.template: Adding shape 'shapes.metadata' to template 'thingworx.template'
[INFO ] 2018-08-13 09:29:16,410 thingworx.template: Adding shape 'shapes.propsubscribe' to template 'thingworx.template'
[INFO ] 2018-08-13 09:29:16,410 thingworx.template: Creating new templates.RemoteBharatForgeVibrationTemplate named 'RemoteBharatForgeVibration'
[INFO ] 2018-08-13 09:29:16,410 RemoteBharatForgeVibration: -- Initializing properties ---------------------
[INFO ] 2018-08-13 09:29:16,410 RemoteBharatForgeVibration: Initialized property avgFreq [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2018-08-13 09:29:16,412 RemoteBharatForgeVibration: Initialized property upToDate [baseType: BOOLEAN, pushType: NEVER, handler: nil, value: true]
[INFO ] 2018-08-13 09:29:16,413 RemoteBharatForgeVibration: Initialized property minFreq [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2018-08-13 09:29:16,414 RemoteBharatForgeVibration: Initialized property maxFreq [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2018-08-13 09:29:16,415 RemoteBharatForgeVibration: Initialized property avgForce [baseType: NUMBER, pushType: ALWAYS, handler: nil, value: 0]
[INFO ] 2018-08-13 09:29:16,415 RemoteBharatForgeVibration: ------------------------------------------------
[INFO ] 2018-08-13 09:29:16,415 Thingworx: Registering identifier *RemoteBharatForgeVibration for thing RemoteBharatForgeVibration
[INFO ] 2018-08-13 09:29:17,417 RemoteBharatForgeVibration: Identifier *RemoteBharatForgeVibration registered with main Thingworx script for for Thing RemoteBharatForgeVibration
[INFO ] 2018-08-13 09:29:19,387 RemoteBharatForgeVibration: -- Starting script --------------------------
[INFO ] 2018-08-13 09:29:19,387 RemoteBharatForgeVibration: Registering core callback handler
[INFO ] 2018-08-13 09:29:19,387 RemoteBharatForgeVibration: Starting main loop
[INFO ] 2018-08-13 09:29:19,387 RemoteBharatForgeVibration: Calling lifecycle start listeners.
[INFO ] 2018-08-13 09:29:19,387 shapes.propsubscribe: Initialized
[INFO ] 2018-08-13 09:29:19,388 thingworx.handler: Creating a new handler.
Velkumar R
