Migrating a thingworx application from twx 8.3 to 8.5 version.
I am facing an issue, when i imports my project file to 8.5 version of twx. Its showing deprecated widgets . Is it possible to migrate complete application from 8.3 to 8.5 or i need to remove manually old widgets añd add new one ?
Thank you
raluca_edu
It is possible, but do it in a test environment first.
When you import mashups in 8.5, widgets are automatically migrated only if you respond to the message that is showing when you open mashup for the first time.
Although, you need to expect a re-work of the mashups after the automatic migration of the widgets.
Please check this reference of migration of widgets: http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FMashup_Builder%2FWidgets%2FMigrationWidgets.html%23wwID0ECQECB
Hope it helps,
Raluca Edu
raluca_edu
Hope it helps,
Raluca Edu
