Migrating from InfluxDB to PostgreSQL
I have a list of streams (InfluxDB as persistence provider) with data in it, and I would like to migrate to Postgres (the default persistence provider)
Now, how can I proceed further? Does Thingworx provide any migration tools?
If I use the export data option, which is not working,
Rocko
If there is an official tool, PTC support will know and be able to provide the link. most probably, this will be a manual effort, but you should create a ticket with support.
I suggest as @Rocko below opening a support ticket, because the Export Data option should be the thing to use here.
Out of curiosity, what exactly is not working?
sabharees15-MoonstoneAuthor
If I export the data from streams using the Export Data option, and then change the persistence provider to Thingworx PP from Influx PP,
I get a successfully imported data message in the application log but am not able to see any data in the stream.
I saw the fact you specified "successfully imported" but I did not see that you imported - is that a typo?.
Specifically the steps should be:
1. Export data from Stream using Export Data
2. Change the Stream's PP (Restart the Stream after changing the PP)
3. Import back the data
