Migrating Issue Thingworx 7.3 to 8.3
I have a problem after finish with Thingworx PostgreSQL 8.3 installation, i plan to import all the entities i have backup before.But the import is failed.
I backup the entities with file entities.twx from Thingworx PostgreSQL 7.3.
Here is the log:
2018-07-12 12:25:30.444+0000 [L: INFO] [O: c.t.w.Importer] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Starting entity import
2018-07-12 12:25:30.464+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Overwrite System Objects : Ignoring Imported Object Except for Permissions Group [Users]
2018-07-12 12:25:30.465+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Create System Objects : Ignoring Imported Object Group [Users]
2018-07-12 12:25:30.480+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Overwrite System Objects : Ignoring Imported Object Except for Permissions Group [Developers]
2018-07-12 12:25:30.481+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Create System Objects : Ignoring Imported Object Group [Developers]
2018-07-12 12:25:30.481+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Overwrite System Objects : Ignoring Imported Object Except for Permissions Group [Designers]
2018-07-12 12:25:30.481+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Create System Objects : Ignoring Imported Object Group [Designers]
2018-07-12 12:25:30.483+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Overwrite System Objects : Ignoring Imported Object Except for Permissions Group [Administrators]
2018-07-12 12:25:30.484+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Create System Objects : Ignoring Imported Object Group [Administrators]
2018-07-12 12:25:30.485+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Overwrite System Objects : Ignoring Imported Object Except for Permissions Group [SecurityAdministrators]
2018-07-12 12:25:30.485+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Create System Objects : Ignoring Imported Object Group [SecurityAdministrators]
2018-07-12 12:25:30.486+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Ignoring Group [Users]
2018-07-12 12:25:30.486+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Ignoring Group [Developers]
2018-07-12 12:25:30.486+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Ignoring Group [Designers]
2018-07-12 12:25:30.486+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Ignoring Group [Administrators]
2018-07-12 12:25:30.486+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Ignoring Group [SecurityAdministrators]
2018-07-12 12:25:30.584+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Overwrite System Objects : Ignoring Imported Object Except for Permissions User [System]
2018-07-12 12:25:30.585+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Create System Objects : Ignoring Imported Object User [System]
2018-07-12 12:25:30.590+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Overwrite System Objects : Ignoring Imported Object Except for Permissions User [SuperUser]
2018-07-12 12:25:30.591+0000 [L: WARN] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Cannot Create System Objects : Ignoring Imported Object User [SuperUser]
2018-07-12 12:25:30.606+0000 [L: ERROR] [O: c.t.c.ImportProcessor] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Unable to process import: User [BMW] Already Exists, With Different Case
2018-07-12 12:25:30.608+0000 [L: ERROR] [O: c.t.w.Importer] [I: ] [U: bmw] [S: ] [T: http-nio-8080-exec-4] Entity import failed
Can someone help me to solve this problem?
*FYI: with or without check Use default Persistence Provider and Include Subsystems has the same result.
Hi @avbee
The warnings / errors are only on the system objects, use default persistence provider option just tells the import utility to import in available default persistence provider (on new ThingWorx instance) in case entities on your previous systems had different persistence provider than the default one (since you are allowed to have more than 1 persistence provider).
Include subsystems is whether or not to import the configuration from old ThingWorx subsystems to new  ThingWorx installation
The warnings you have shared is on the system objects & user  which as the warning highlights already exists 🙂
Are you seeing more errors other than what you have shared below?
avbee1-VisitorAuthor
@supandey yes, here is it.
Most the warns appear to be on the system objects, for rest of the custom entities error out during import is because they already exist in the system.
Are you running into some specific issue while working with these imported entities?
