Oct 23, 2025 12:00 PM UTC
Missing Dependency open-tabs in Thingworx Mashup
Hi all,
On version 10.0.0 and this is an issue I am just noticing as of recent (maybe just after updating our dev to 10.0.0). There is this dependency with an entity called 'open-tabs' but I don't see it used anywhere in the mashup and don't even know what the entity is (based on name seems like a default thingworx entity). Any ideas on what this is or how to resolve this dependency?
Oct 23, 2025 5:12 PM UTC
Thanks for the input. For now, simply creating a new style named 'open-tabs' seems to resolve the dependency, just seemed like a weird behavior so wanted to see if anyone else encountered it
Oct 23, 2025 1:56 PM UTC
Icon indicates that it is a StyleDefinition.
Maybe export the mashup as xml (export to sourcecontrol) and search the xml for the "open-tabs" reference. Maybe it helps to recreate the StyleDefinition - or remove it when you know where it is referenced in the mashup.
Not sure if this was a custom created StyleDefinition or from some other extension.
Oct 23, 2025 2:02 PM UTC
I found it has something to with this TabStyle property which is new in TWX 10.0.0.
If I switch it to "Framed Tabs", I then have an issue with a style definition called 'contained-tabs' instead. Though I don't see anywhere to switch the actual style definition that is used and open-tabs was not a custom created one. I find that creating a custom style definition named 'open-tabs' resolves the dependency issue, just am not sure if I am missing some sort of new built-in/system dependency named 'open-tabs' instead.
Oct 23, 2025 2:40 PM UTC
"TabStyle" : "open-tabs"
XML shows me also that it is with the TabStyle, but I can't physically remove it from the mashup in any way it doesn't seem.
Ascherer17
Jan 22, 2026 10:19 PM UTC
Just for awareness in case others show up here, I encountered this issue in ThingWorx v10.1.0, so it's not yet resolved.
Thank you for sharing the tip about creating a style to overcome the dependency!
Jul 7, 2026 5:44 PM UTC
If anyone from PTC views this, I am wondering if it will be resolved ever. I still have an issue where if I use tabs outside of the project that I created the ‘open-tabs’ entity, then it has dependencies to other projects
