Alessio15-MoonstoneAuthor
So there is no specific guide for the trial installer? Does JAVA_HOME need to be defined? Should the JDK bin be in the PATH?
Anyway, the two links I pointed out before are broken and must be fixed, or removed.
Hello Alessio,
Yes, as it seems unfortunately the two links are broken at the moment. I just tried the installation of the trial and for me setting JAVA_HOME and JDK in PATH was not necessary.
