missing services while adding data to mashup
I have the same issue. This ServiceableTS was never created in this course. How should i create this ThingShape?
22-Sapphire I
Looks like you are following some sort of exercise?
Usually when you create a service in Composer and execute it in composer, if the output is an infotable, you can then select 'Create DataShape based on result' to create the necessary DataShape and then add that to the output of the service.
Sorry I'm just guessing as to what your issue is based on what you wrote.
Support
Hi @JT_9169312
Please provide a link to the tutorial you are referencing so we can check it out.
--Sharon
