Modify the cell value in Grid
I need to modify the grid cell data based on its original value.
Scenario: I have a grid with column name "Status", Actual status columns values will be "true/false". But, instead of true I need to show the Active and instead of false, I need to show the In-Active. Please help me on the same.
Noor
22-Sapphire I
You can wrap the service that is retrieving this information and then use DeriveFields to create two new columns
or even in the acquiring query potentially you can do that transform (if it is an sql query you can use a case statement in that).
You could even use localization tokens.
snoor1-VisitorAuthor
Hi  @PaiChung,
I got your point. but still, I am looking for the above scenario, wherein angular we can define the cell value based on the grid value comparison in the grid definition only.
Noor
