Modifying a Data Table entry
Hey guys,
I've been having a problem with modifying a data table entry, I've tried all Data Table services but none of them worked, not even the UpdateDataTableEntry, I don't want to delete it and create another one with the information modified as it does in AssignDataTableEntries.
Thank you
tscurAnswer
Problem solved. My issue was that I was using to many keys and when I changed it, it wouldn't update, it would add another entry. Thank you!
22-Sapphire I
What is happening when you try the Update or the AddOrUpdate services?
tscur1-VisitorAuthor
Maybe I didn't understand the service correctly, but the input it asks is an info table values, what I did was inputting the new values of the row (even the ones that have to stay the same) to update only one field of the row I selected (in my grid). With the Add/Update it added another entry with almost the same field values but with the change I made. I don't want to redo all my infotable or delete/add the entry modified, I just want to change the field value of one entry.
tscur1-VisitorAuthorAnswer
Use Home mash up of data table where you can easily update any value in the table/Use addorupdatedatatableentry() service.
With regards
Yedukrishnan
