7-Bedrock
MQTT payload to thingworx
I successfully connected mqtt to kepware and able to see the payloads when view under QuickConnect, bu the the payload was not display in the Industrial Connection. I can see other parameters under Industrial Connection........only except the payloads
slangleyAnswer
Support
Hi @MK_10628719.
I recommend taking a look at this guide in the IoT Tips forum on community.  If you still have issues after reviewing it, please let us know.  It would be helpful for you to provide any errors seen in the logs and screenshots of your configuration.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @MK_10628719.
--Sharon
