8-Gravel
Jan 6, 2022 2:09 AM UTC
MQTT Subscriber things can't trigger subscription
Hi all
I'm create a Things based on MQTT Subcriber  and connect to MQTT broker. i'm using subcription on this Things with datachange events.
When i'm change properties value with mqtt broker, the subcription is not triggered.  But when i'm use UI change value, the subcription still work.
I'm changed Properties Data Change Type from Value to Alway. And  I have set visibility to ThingworxPeristentProvider for System User by reading similar topics but the situation is not changed.
P/S: I'm create a Things based on MQTT (combine connection and subcriber), it's still work.
Please support me, thanks.
Jan 6, 2022 6:46 AM UTC
Hello @Nguyen_Khue ,
Pls find detailed article on MQTT https://www.ptc.com/en/support/article/CS246701
A Quick Start guide https://community.ptc.com/t5/IoT-Tech-Tips/MQTT-Extension-Quick-Start-Guide/m-p/595294#M1248
Kindly revert back if you still need any info.
Regards
Bhawna
8-Gravel
Jan 6, 2022 8:21 AM UTC
Yep, i already read and do same way. But i can't find document for Subcription MQTT.  The problem is Subcription still work with MQTT type, but don't work with MQTT Subcriber
Jan 6, 2022 8:29 AM UTC
Hi @Nguyen_Khue ,
Have you enabled the SSL?
Can you please share the screenshots or errors you are getting?
Regards
Bhawna
