MQTT Thing not connecting to my local MQTT server.
i created a MQTT Thing using MQTT extension also configure it with correct  password , IP, and port but still its not connecting to my local MQTT server.
my mqtt server is running on raspberry pi which is connected to my PC vai ethernet. also i'm using local instance of thingworx on my pc.
please help!
Support
Hi @ileadershiptech.
Apologies for the oversight on responding to this post.
To assist, we would need more information regarding the issue.  Are you receiving an error?  Please provide the logs from ThingWorx and the Raspberry Pi to investigate possible causes.  Please also provide the versions you are running.
--Sharon
22-Sapphire I
Can you also please provide the complete configuration?
Did you create the appropriate properties for example?
