Multi line status message
Is is possible to generate a multi line message for the status message widget.
Looking to display a number of status messages i.e.
error 1
error 2
I have tried inserting the new line character (\n) but the widget still draws on a single line. If I output the same text to a text area widget it does display on multiple lines
Thanks in advance
K
    abhiramkAnswer
    Not sure, how to tweak the status message but, as you mentioned it's showing multi-line in textArea, use that only as workaround.
    some event will be triggering the status message and you are already passing some static/dynamic message right. Instead of passing it to status message, keep small popup with text area and bind the message which you want to display.
    When event triggers show that message in the popup and you can also keep ok button to acknowledge the message, on click of 'Ok button' close mashup or keep some time and close mashup as a workaround.
    If it fits your use case or okay with the UX. You can try this.
    abhiramk1-VisitorAnswer
    khayes11-VisitorAuthor
    thanks for the reply. I will keep it in mind as a good alternative thank you. I'll leave the ticket open for now in case someone knows a way to fix the original problem via the status message, if not then I'll close it.
