Sep 27, 2022 6:42 PM UTC
Multilevel drill down using drop downs.
We have a scenario where we have multiple drop-downs. All the drop-downs are connected with each other in a multi-level hierarchy. All the drop downs are associated with the same Datatable with different fields.
For example: we have a Datatable  named DT with 4 fields FD1,FD2,FD3, and FD4. The dropdowns viz DD1, DD2,DD3, and DD4 are binded to the corresponding fields of DT; DD1 binded to FD1, DD2 binded to FD2, and so on..
So when we select a value in DD1 from the list of selections, it should filter the values in DD2 based on Selection of value in DD1. Then data on DD3 should be filtered based on selection in DD2, then data on DD4 should be filtered based on selection made in DD3.
is there any way to achieve this in a mashup.
Sep 28, 2022 11:22 AM UTC
  • Create a 4 different services for each drop-down widget
  • Based on each service's "SelectedRowChanged" event execute the subsequent service with "SelectedValue" as service input
Note: We can optimize this further, this is simplest I believe.
Sep 29, 2022 5:28 PM UTC
Thanks for your reply.
As per your comment, I created 4 services inside a helper thing.
Based on each service 'SelectedRowChanged' event I execute subsequent service with 'selectedvalue' as service input. But I don't get any option to bind the output of the triggered service to the subsequent dropdown(DD2). how the binding is going to be in this case? Please suggest.
Sep 30, 2022 5:16 AM UTC
