Need Triangle shape in a mashup
I have a similar requirement to orient the image from 0-359 deg. It would be glad if you could share the code for developing the extension along with the option to change the image used.
Thanks in advance
Sarma
20-Turquoise
You could modify an existing extension or implement your own. I don't have a sample code (but like I said, you can take a look at the existing ThingWorx widgets and modify), attaching the documentation on custom extensibility.
