Apr 17, 2025 4:19 PM UTC
.NET Edge - api_requesthandler: No handled found
When I run my edge, everything works fine. However, I notice a message keep showing periodically:
INFO com.thingworx.communications.client.TwApiWrapper - api_requesthandler: No handler found. Returning 404
My device works fine, and I am able to run and control my remote properties and services.
Is there an explanation why i have this message ? Can I remove it ?
-.NET Edge 5.9 with .NET8
-Thingworx 9.5.1
smainenteAnswer
Jun 4, 2025 7:21 AM UTC
Note that you might be impacted by https://www.ptc.com/en/support/article/CS445092 in NSDK 5.9.0
Apr 18, 2025 8:26 AM UTC
This is maybe related to https://www.ptc.com/en/support/article/CS423838.
Do you see mention to SynchronizeModelState around that error or on the platform at the same time? If so, you can ignore that message. The platform is attempting to use a feature not implemented in your SDK version and will fall back to the old behavior.
Regards
Apr 30, 2025 2:37 PM UTC
No, I don't have the message containing : SynchronizeModelState
May 5, 2025 10:12 AM UTC
Can you please share more logs around that api_requesthandler message ? Maybe change the logger level to DEBUG.
