Not able to connect EMS to thingworx evaluation trial server.
I am trying to connect EMS to thingworx trail evaluation server but the web socket is not getting connected.
Below are the jason.config file i am using:
"ws_servers": [{
"host": "pp-18102412130w.devportal.ptc.io",
"port": 443
"appKey": "XXXXXXXXXXXXXXXXXXXXXXXX",
"certificates": {
"validate": false,
"cert_chain": ["certificate.cer"]
"logger": {
"level":"INFO",
"publish_directory":"logs",
"publish_level":"INFO",
"max_file_storage":2000000,
"auto_flush":true,
"flush_chunk_size": 16384,
"buffer_size" : 4096
"file": {
"virtual_dirs": [
{"logs": "logs"},
{"instruction":"instruction"}
"staging_dir": "C:\\Projects\\PTCDocs\\PTC_Work\\EMS\\microserver\\staging"
And the error i  am getting:
C:\Projects\PTCDocs\PTC_Work\EMS\microserver>wsems
[INFO ] 2018-10-26 15:50:01,552 wsems: Using config file: C:\Projects\PTCDocs\PTC_Work\EMS\microserver\etc\config.json
[FORCE] 2018-10-26 15:50:01,552 wsems: Starting up ....
[FORCE] 2018-10-26 15:50:01,581 wsems: Initializing EMS ....
[FORCE] 2018-10-26 15:50:01,581 main: Using config file C:\Projects\PTCDocs\PTC_Work\EMS\microserver\etc\config.json
[INFO ] 2018-10-26 15:50:01,581 wsems: Creating the WsEms proxy.
[INFO ] 2018-10-26 15:50:01,581 wsems: Starting HTTP Server.
[INFO ] 2018-10-26 15:50:01,582 wsems: Initializing the ThingWorx REST interface.
[FORCE] 2018-10-26 15:50:01,584 httpServer: starting http server port=8000
[INFO ] 2018-10-26 15:50:01,716 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2018-10-26 15:50:01,717 wsems: Starting the connection.
pp-18102412130w.devportal.ptc.io:443-->[ERROR] 2018-10-26 15:50:02,76 SDK: Error intializing SSL connection
[ERROR] 2018-10-26 15:50:02,76 SDK: twWs_Connect: Error restarting socket. Error 126
Please help, I think the server is not getting connected.
Please check the host " https://PP-18102412130W.devportal.ptc.io/Thingworx"
Thanks and regards
Saurabh.
Sorry its config.json file, typing mistake.
Please resolve my issue its urgent.
Hi @SaurabhHCL,
Can you please try the below configuration in your config file and make the relevant changes as per your environment.
	"ws_servers": [{
		"port": 443
	 "http_server": {
 "host": "127.0.0.1",
 "port": 8080,
 "ssl": false,
 "authenticate": false
	"certificates": {
		"validate": false,
	"logger": {
		"level": "INFO",
		"publish_directory": "logs",
		"publish_level": "INFO",
		"max_file_storage": 2000000,
		"auto_flush": true,
		"buffer_size": 4096
 "ws_connection": {
 "encryption": "ssl",
 "verbose": true,
 "msg_timeout": 1000
	"file": {
		"virtual_dirs": [{
				"logs": "logs"
				"instruction": "instruction"
Himanshu
Hi Himanshu,
Thanks for your response.
Still not working, this is my app key "5d6d4f8c-320b-4c1e-8bbc-5747c0742379"
can you please try at your end and see if it works.
Also do we need to give some permissions from the composer also ?
As i have created an appkey only.
Thanks and regards
Saurabh.
use below config file and make appropriate changes to it
and also do validate the appKey expiry date from composer as well.( extend the date)
"ws_servers": [{
"host": "vdccwp1259.logon.ds.ge.com",
"port": 443
"appKey": "ba4c0ded-4f5f-4069-91be-8ca9a084777a",
"ws_connection": {
"verbose": true,
"binary_mode": true,
"msg_timeout": 5000,
"ping_rate": 55000,
"pingpong_timeout": 10000,
"connect_period": 60000,
"duty_cycle": 100,
"message_idle_time": 50 ,
"max_msg_size": 1048576,
"message_chunk_size": 8192,
"max_frame_size": 8192,
"max_messages": 500,
"connect_on_demand": false,
"connect_timeout": 10000,
"connect_retry_interval": 10000,
"max_threads": 4,
"max_connect_delay" : 0,
"socket_read_timeout" : 100,
"frame_read_timeout": 10000,
"ssl_read_timeout": 500,
"connect_retries" : -1
"logger": {
"level": "TRACE",
"publish_directory": "c:\\Microserver\\logs",
"publish_level": "TRACE",
"auto_flush": true
"certificates": {
"validate": true,
"allow_self_signed": false,
"cert_chain": ["c:/Microserver/certificates/exported_rootcacert.pem"]
"http_server": {
"host" : "localhost",
"port" : 8000,
"ssl" : false,
"authenticate" : false
"auto_bind": [{
"name": "IS.PL02.RemoteRepository",
"port": 443
"file": {
"virtual_dirs":[
{ "In" : "C:\Microserver\\In" },
{ "Out": "C:\\Microserver\\out" },
{ "staging": "C:\Microserver\\staging"}
"staging_dir": "staging"
