Not able to connect external Sql Database
Hello Team,
I am trying to connect my ThingWorx with external Db but not able to do so. I could see following error in the logs
Classname not found: com.microsoft.sqlserver.jdbc.SQLServerDriver
Any help will be appreciated .
Hi @RB_10191565 ,
Kindly check the article linked below.
https://www.ptc.com/en/support/article/cs314904
revert back if issue is still present.
Regards
Bhawna
Hi @RB_10191565 ,
Regards
Bhawna
