Not able to delete Analytics extension
Hello everyone,
i am trying to delete the Analytics extension from my composer. While following these steps, i cant delete the ThingWorx_Analytics_Builder_Extension because "the following Extension entities are still in use: AnalyticsServerFiltersInstance".
Examining this entity i found out it depends on the TW_ML_Helper Thing and thus can't be deleted. So tried to delete the TW_ML_Helpter thing, but this can't be deleted because it is an extension Entity. Also Its services which remove the filters do not remove the AnalyticsServerFiltersInstance.
When i try to forcibly remove the extensions via the ThingworxStorage/extensions folder, these folderes get recreated once i restard tomcat.
Any ideas how to solve this?
Kind Regards,
Dominik
pshubhamAnswer
Hi Dominik,
This is a known issue for the version 8.1 and is fixed in the version 8.2.1.
Prakhar Shubham
pshubham5-Regular MemberAnswer
Hi Dominik,
Prakhar Shubham
drieder1-VisitorAuthor
I see, i will upgrade then as fast as possible. Thank you
