Not able to license thingworx
im not able to relicense my thingworx 8.4 with eclipse extension.
When I try to license thingworx via Licensing subsystem, I get the following error:
"Unable to Invoke Service AcquireLicense on LicensingSubsystem : Unable to acquire ptc_navigate_view: Trusted storage hostid does not match system hostid.[Ljava.lang.StackTraceElement;@7d003582"
What is the reason for this?
We double checked the Device Id, so this shouldnt be the Problem.
Thanks in advance
raluca_edu
Seems to be an issue with trusted storage and this need to be verified in a Support case.
Please open a case with PTC Support.
Thank you,
Raluca Edu
Support
Hi @vartush.
It sounds like you are either using a license for another system or something happened to change your Device ID.  If ThingWorx is running, log in to Composer and browse to Subsystems > Licensing Subsystem.  Select Services and execute the GetInstanceID service.  This will return the Device ID to be used for generating a new license.
If you're unable to perform the above steps, a case will be needed to work through the issue.  I will be happy to open one on your behalf.
--Sharon
Support
Hi @vartush.
If one of the previous responses allowed you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
--Sharon
