Not Able to Register RemoteThing on EMS using Lua Script
Hi Team -
I am trying to run the Respberry Pi example from the Guides.
Everything is working fine and my TW Server, EMS Server and LuaResource is talking to each other.
However - LuaResource is NOT able to register the RemoteThing on EMS server.
Its getting stuck at
[DEBUG] 2018-03-01 15:13:19,864 thingworx.server: Invoking /Thingworx/Things/LocalEms/Services/AddEdgeThing on server. content: {"keepalive":60000,"port":"8001","timeout":15000,"host":"127.0.0.1","proto":"http","name":"*ExampleThing","path":"/scripts/Thingworx"}
[TRACE] 2018-03-01 15:13:19,865 luaBindings:newRapClient: Found RAP at 127.0.0.1:8080
[TRACE] 2018-03-01 15:13:19,865 luaBindings: Got RAP timeout: 0
[TRACE] 2018-03-01 15:13:19,865 luaRapBindings: Self Signed certificates are enabled for the RAP conneciton.
[TRACE] 2018-03-01 15:13:19,865 luaRapBindings: Certificate validation is disabled for the RAP conneciton.
[DEBUG] 2018-03-01 15:13:19,866 SDK: twTlsClient_Create: Initializing TLS Client
it makes a call to EMS server and waits for sometime and EMS server closes the twTlsClient.
Any suggestions pls? Attached is Config.jason and Config.lua files...
The Raspberry Pi Quickstart guide has been updated with a link to download the latest version of EMS and instructions for connecting to the hosted trial ThingWorx instances that now use https.
https://developer.thingworx.com/resources/guides/thingworx-raspberry-pi-quickstart/install-ems
Per our messages, it also sounds like the ThingWorx SDK was a better solution for you.
-- Craig A.
pbatwal1-VisitorAuthor
Thanks Craig. Yes.. I think rather than investing so much time in EMS and learning Lua Script, its best to use C or Java SDK. It gives you more control.
BTW - I am not able to figure out what was changed in EMS server new documentation?
Craig - Its still not working - Same Issue !
Were you able to connect to your EMS expert in Germany?
I am also facing the same problem.
Running lua script in raspberry pi stuck at
[INFO ] 2018-12-14 21:36:56,534 thingworx.handler: Creating a new handler.
[DEBUG] 2018-12-14 21:36:56,538 thingworx.server: Invoking /Thingworx/Things/LocalEms/Services/AddEdgeThing on server. content: {"keepalive":60000,"port":"8001","timeout":15000,"host":"192.168.1.101","proto":"http","name":"PiThing","path":"/scripts/Thingworx"}
[DEBUG] 2018-12-14 21:36:56,538 SDK: twTlsClient_Create: Initializing TLS Client
Kindly help...!!!
