Not able to sign in into thingworx composer 7.2 in dev zone with my credentials
  • September 15, 2016
  • 2 replies
  • 1313 views
As title itself stated I am trying to sign in into thingworx composer of dev zone after updation of foundation server to 7.2 with new given password but its nighter signing inn my composer nor giving any error.
I am trying to signing in to ip address given by thingworx foundation server.
then I supplied credential as:
username: Administrator
Password: given by thingworx foundation server
Meenakshi
Best answer by rupadhyay
Please go to the http://developer.thingworx.com/dashboard and start Foundation server and then try to login. Please don't try to directly  use the IP before starting the foundation Server. I am not sure if there is any time limit after whichit will get shut down , but it got in my case .
I faced the similar issue , tried after starting the Foundation Server and it works .
Let me know , if it helps.
rupadhyay1-VisitorAnswer
magrawal1-VisitorAuthor
yeah it worked.
don't know the reason how it launched foundation server now because when I tried to launch foundation server before it was throwing error of : null organization name, so I was trying to login by direct IP address and it was not letting me into thingworx.
btw Thanks
