Not able to start Tomcat
Tomcat is not getting started. When I attempt to start it stops immediately. Here I am attaching the application log file also for reference.
yesterday, I have created some schedulers and based on the scheduler running some services.
created One scheduler(configured every 5 minutes - 0 0/5 * * * ?) to update a property(persisted) value from its present value plus 5
another scheduler to query named property history of some properties at 2 to 4 pm.
Today my Tomcat is not opening. Is this the cause for the above problem in any ways?
SruthiAnswer
Found the solution. the URL should be like this, 127.0.0.1/Thingworx/Composer
not 127.0.0.1/Thingworx.
if Tomcat isn't starting it is better to review the catalina logfile.
The application.log you provided has no visible error (for me) which indicates why tomcat isn't starting
Sruthi15-MoonstoneAuthor
I am not able to find the catalina log file. can you tell me where it resides?
it is in the tomcat folder, subfolder "logs" (like $CATALINA_HOME/logs on *nix systems)
Support
Hi @Sruthi.
Please attach all current logs in the <tomcat_home>\logs and \ThingworxStorage\logs folder.so we can assess.
--Sharon
