Not able to ThingWorx analytics server from Thingworx analytics builder in ThingWorx analytics trial
I have installed the ThingWorx analytics trial version for 8.2 which runs on Docker for Windows. After launching the analytics builder using the below URL I am trying to configure the analytics server. I am not getting a verification confirmation message as expected. My analytics server and microservices are running fine. although. Any help on this.
http://localhost:8080/Thingworx/Runtime/index.html#master=TW_ML_Master_v1&mashup=TW_ML_Settings_v1
Docker Ps gives the below result:
C:\Windows\system32>docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
2cf8407595e7 twxml/analytics-server-edge-standalone:4.1.1 "java -jar /maven/an…" 13 days ago Up 17 minutes 0.0.0.0:9900->8080/tcp, 0.0.0.0:9901->8081/tcp edgems
efee47b84e0e ptc/configurable-nginx:1.10.2 "/etc/nginx/customSt…" 13 days ago Up 17 minutes 443/tcp, 0.0.0.0:9800->80/tcp nginx
7ef4642d7fbf twxml/prescriptive-standalone:4.1.3 "java -Dvariables.fi…" 13 days ago Up 17 minutes 0.0.0.0:9700->8080/tcp, 0.0.0.0:9701->8081/tcp prescriptivems
6d134733a7bb twxml/predictive-standalone:4.1.3 "java -Dvariables.fi…" 13 days ago Up 17 minutes 0.0.0.0:9600->8080/tcp, 0.0.0.0:9601->8081/tcp predictionms
ae02427e82e5 twxml/validation-standalone:4.1.2 "java -Dvariables.fi…" 13 days ago Up 17 minutes 0.0.0.0:9500->8080/tcp, 0.0.0.0:9501->8081/tcp validationms
a7c391256084 twxml/training-standalone:4.1.1 "java -Dvariables.fi…" 13 days ago Up 17 minutes 0.0.0.0:9400->8080/tcp, 0.0.0.0:9401->8081/tcp trainingms
f31bcbf0b90f twxml/clustering-standalone:4.1.1 "java -Dvariables.fi…" 13 days ago Up 17 minutes 0.0.0.0:9300->8080/tcp, 0.0.0.0:9301->8081/tcp clusteringms
30deab7330fe twxml/profiles-standalone:4.1.1 "java -Dvariables.fi…" 13 days ago Up 17 minutes 0.0.0.0:9200->8080/tcp, 0.0.0.0:9201->8081/tcp profilingms
2268e32befa0 twxml/analytics-standalone:4.1.1 "java -Dvariables.fi…" 13 days ago Up 17 minutes 0.0.0.0:9100->8080/tcp, 0.0.0.0:9101->8081/tcp signalsms
8228d5c15ce4 twxml/data-standalone:4.1.1 "java -Dvariables.fi…" 13 days ago Up 17 minutes 0.0.0.0:9000->8080/tcp, 0.0.0.0:9001->8081/tcp datams
b3550280bffb twxml/result-standalone:4.1.1 "java -Dvariables.fi…" 13 days ago Up 17 minutes 0.0.0.0:8900->8080/tcp, 0.0.0.0:8901->8081/tcp resultsms
80e80f947606 twxml/training-standalone:2.0.5 "java -Dproperties.f…" 13 days ago Up 17 minutes 0.0.0.0:9090->8080/tcp, 0.0.0.0:9091->8081/tcp iadtrainingms
10281c9f23c5 twxml/result-standalone:2.0.3 "java -Dproperties.f…" 13 days ago Up 17 minutes 0.0.0.0:9080->8080/tcp, 0.0.0.0:9081->8081/tcp iadresultms
07a14bfbe843 installer/twx/thingworx-foundation-h2:8.2.0-b278 "tpg-catalina.sh run" 2 weeks ago Up 18 minutes 0.0.0.0:8080->8080/tcp, 8443/tcp twxfoundation
cmorfinAnswer
Hi
This article may help: https://www.ptc.com/en/support/article?n=CS250253
Kind regards
Christophe
Getting the below message from logs on viewing the builder Mashup standalone.
Error in invoking service Things_TW_ML_Helper, CreateTempAnalyticsServerRuntimeInstanceAMS, Things, TW_ML_Helper, Services, CreateTempAnalyticsServerRuntimeInstanceAMS. Error from the server: "Error executing service CreateTempAnalyticsServerRuntimeInstanceAMS. Message :: Invalid Global Session Parameter [TempAnalyticsServerRuntimeInstance] - See Script Error Log for more details."
cmorfin19-TanzaniteAnswer
Hi
Kind regards
Christophe
already gone through it. Its working fine now. Forgot to update here. Thanks a lot.
